S10506X 密码丢失
2026-09-23提问
  • 0收藏,331浏览
吴帅 零段
S10506X 两台堆叠 登录密码丢失,console账号密码也丢失,如何在不影响业务的情况下,重置密码
3.1 进入bootroom菜单清除Console密码
通过console线和crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”的时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择“<6> Skip Current System Configuration”跳过当前配置启动,不同设备可能不是数字6,
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
save
The current configuration will be written to the device. Are you sure? [Y/N]:y
Please input the file name(*.cfg)[flash:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):(输入回车)
flash:/startup.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait...
Configuration is saved to device successfully.
reboot
Start to check configuration with next startup configuration file, please wait.........DONE!
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
This command will reboot the device. Continue? [Y/N]:y
3.3 如果需要之前的配置信息的话
#Apr 26 12:02:07:166 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1: login from Console
%Apr 26 12:02:07:306 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
dir  %查看设备配置文件
Directory of flash:/
   1     drw-         -  Apr 26 2000 12:00:20   logfile
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
   3     -rw-      1556  Apr 26 2000 12:05:33   _startup_bak.cfg
   4     -rw-       151  Apr 26 2000 12:05:30   system.xml
29106 KB total (16876 KB free)
给设备和电脑配置成同网段IP地址(举例:WAC配置成192.168.100.1,电脑配置成192.168.100.2),在电脑上通过3CD软件搭建tftp服务器。
sys
System View: return to User View with Ctrl+Z.
[H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
    Reply from 192.168.100.2: bytes=56 Sequence=2 ttl=128 time=2 ms
tftp 192.168.100.2 put startup.cfg
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 second(s).
  File uploaded successfully.
下载成功:
可以到本地相关路径(此例子中是E盘)查看到相关文件。
需要恢复之前配置
解决方法:删除密码恢复之前配置文件
使用记事本打开startup.cfg文件
删除aux0口下的认证方式和密码并保存文件
覆盖当前配置文件
tftp 192.168.100.20 get startup.cfg
The file startup.cfg exists. Overwrite it? [Y/N]:y
  Verifying server file...
  Deleting the old file, please wait...
  Downloading file from remote TFTP server, please wait....
  TFTP:     1166 bytes received in 0 second(s)
  File downloaded successfully.
reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n 不保存配置
This command will reboot the device. Continue? [Y/N]:y 确定继续重启
4 个回答
粉丝:17人 关注:9人
您好,S10506X 两台IRF堆叠且Console/登录密码均丢失时,无法在完全不中断业务的情况下通过空配置启动绕过(会断业务)。
如果必须保留业务,请优先联系H3C 400获取临时后台账号(若设备开通了相关特性)。
若必须手动重置,且能接受业务中断(约5-10分钟,视重启速度),请按以下步骤操作(假设使用主控板为LSQM1MPUE0):
关键步骤(单机/主备同理,IRF需操作主设备):
1. 通过Console线连接主设备主控板的Console口。
2. 重启主设备,在Bootware(BootROM)菜单按 Ctrl+B 进入(默认密码通常为空或 Admin@h3c.com)。
3. 选择 <6> Skip Current Configuration(跳过当前配置启动)。
4. 继续引导启动(按 0 或 Enter)。
5. 设备启动后,不要保存配置,直接在用户视图下输入 sys 进入系统视图。
6. 导出配置:display saved-configuration 将当前配置复制出来(保留IRF等关键配置)。
7. 重置密码:
h3c
local-user admin class manage
password simple NewPassword@123
8. 重新加载配置并修复(防止IRF分裂):
方法A:将配置复制到记事本,删除旧密码行,通过TFTP/FTP上传为 startup.cfg,然后 startup saved-configuration startup.cfg 并重启。
方法B:在空配置模式下,手动恢复IRF配置及业务配置,同时修改密码,最后保存。
提示:操作前请务必准备好Console线,并记录好IRF端口配置。为了数据安全,建议联系H3C技术支持。
粉丝:36人 关注:1人
在不影响业务的前提下重置 S10506X 堆叠的登录密码,核心挑战在于 IRF 的配置同步机制。如果只操作一台,配置可能会同步到另一台,导致密码重置无效。因此,关键在于选择正确的操作对象并控制配置同步。
 核心方案:利用 IRF 主备切换,在备机上操作
最安全的方法是利用 IRF 的冗余特性,先在备机(Standby)上完成密码重置,再通过主备切换让备机成为主机,最后重置原主机。整个过程备机始终有一台在承载业务,理论上可实现业务不中断。
操作前提:你需要通过 Console 口物理连接到设备。由于 Console 密码也已丢失,你需要先通过 BootWare 菜单进入系统。
第一阶段:在备机上重置密码(备机此时不承载业务)
  1. 连接并重启备机:将 Console 线连接到备机的 Console 口,然后重启该备机。
  2. 进入 BootWare 菜单:在启动过程中,当终端出现 Press Ctrl+B to access EXTENDED-BOOTWARE MENU... 提示时,迅速按下 Ctrl+B,密码通常为空,直接回车。
  3. 选择跳过 Console 认证:在 BootWare 菜单中,选择 <8> Skip Authentication for Console Login(跳过 Console 登录认证)。这个操作只会临时清除 Console 密码,不会影响现有业务配置。
  4. 进入系统并修改密码:选择 <0> Reboot 重启,设备启动后你将无需密码直接进入命令行。此时,立即修改本地用户密码和 Console 密码:
    bash
    system-view local-user admin class manage password simple 你的新密码 authorization-attribute user-role network-admin quit line con 1/1 # S10506X Console 口通常为 con 1/1 authentication-mode password set authentication password simple 你的新密码 quit save force
    注意:此时修改的配置可能尚未同步到主机,这是正常的。
第二阶段:主备切换与主机密码重置
  1. 触发主备切换:在原主机上执行 reboot 命令重启,或者将原主机断电。IRF 会自动选举原备机(已修改密码的那台)成为新的主机,业务由它承载,此过程通常对业务无感知。
  2. 重置原主机(现为备机)密码:待原主机重启完成并重新加入 IRF 成为备机后,对它重复第一阶段的 1-4 步操作,重置其密码。
  3. 验证与保存:两台设备密码均重置完成后,在当前主机上执行 save force,配置会同步到备机,确保密码持久化。
⚠️ 关键风险与注意事项
  • 配置同步风险:在 IRF 中,主机的配置会同步到备机。如果你直接在主机上修改密码,备机可能不会同步,或者在你重启备机时,备机的旧配置会覆盖修改。上述“先备后主”的顺序就是为了规避此风险。
  • 密码恢复功能状态:如果设备上 password-recovery 功能被关闭,BootWare 菜单可能没有 <8> 选项。此时只能选择 <6> Skip Current System Configuration(跳过当前配置启动),但这样会以空配置启动,导致业务中断,需要手动恢复配置。在执行前,请务必确认你的设备 password-recovery 功能处于开启状态。
  • Console 口位置:S10506X 的 Console 口通常位于主控板(MPU)上,请确保你连接的是正确的槽位。在 IRF 环境下,务必连接主设备的 Console 口进行操作,从设备的 Console 口可能无法进入 BootWare 或进行有效配置。
  • 业务影响评估:虽然 IRF 设计上支持无缝切换,但任何涉及设备重启的操作都存在潜在风险。强烈建议在业务窗口期进行,并提前确认备机能够正常接管全部业务流量。如果业务对中断极其敏感,且没有窗口期,最稳妥的方式是联系 H3C 技术支持(400-810-0504),在工程师指导下操作。
粉丝:13人 关注:7人
如若是堆叠设备、且需要重启设备进入bootware操作的,参考如下:
(1) 给备设备断电,然后通过console口连接主设备后将主设备重新启动。
(2) 设备重启时按下Ctrl+B进入bootware菜单,选择跳过当前配置启动。
(3) 选择Reboot重启设备。
(4) 设备重启时按下Ctrl+C或Ctrl+D跳过自动配置;
(5) 按下Enter键成功跳过配置文件启动。
(6) 查看配置文件内容。
more startup.cfg
(7) 将配置文件全部选中后复制粘贴到本地。
(8) 修改配置文件,配置新密码为hello12345。并将配置文件保存为startup.cfg文件,使用tftp方式导入主设备。如果文件名字为其他的,需要通过startup命令 指定下一次启动使用新的配置文件
(9) 重启主设备,新配置生效。
(11) 主设备启动好后,再启动备设备。让备设备重新加入堆叠组。
问问400吧,目前查到的资料是需要断业务的
重启进bootrom
