无法进入system-view界面
2022-03-07提问
  • 1收藏,4363浏览
输入system-view显示未识别的命令
4 个回答
粉丝:3人 关注:0人
什么设备? 有的设备不支持命令行  要进WEB界面
zhiliao_K3ypkU 知了小白
S5120系列
zhiliao_K3ypkU 知了小白
已解决,首次登录需要web登录。https://www.h3c.com/cn/d_201709/1032637_30005_0.htm
S5120-28P-poe-winet
<H3C>summary Select menu option: Summary IP Method: Manual IP address: 192.168.0.233 Subnet mask: 255.255.255.0 Default gateway: IPv6 Method: IPv6 link-local address: IPv6 subnet mask length: IPv6 global address: IPv6 subnet mask length: IPv6 default gateway: Current boot app is: flash:/S5120WiNet-CMW520-R1513P81.bin Next main boot app is: flash:/s5120winet-cmw520-r1513p81.bin Next backup boot app is: NULL H3C Comware Platform Software Comware Software, Version 5.20, Release 1513P81 Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S5120-28P-POE-WiNet uptime is 0 week, 0 day, 0 hour, 23 minutes H3C S5120-28P-POE-WiNet 128M bytes DRAM 128M bytes Nand Flash Memory Config Register points to Nand Flash Hardware Version is REV.A CPLD Version is 001 Bootrom Version is 169 PSE Software Version is 390 [SubSlot 0] 24GE+4SFP+POE Hardware Version is REV.A
 <H3C>system-view ^ % Unrecognized command found at "^" position
只能使用以下几个命令
<H3C>? User view commands:
 initialize Delete the startup configuration file and reboot system
 ipsetup Assign an IP address to VLAN-interface 1
 password Specify password of local user
 ping Ping function
 quit Exit from current command view
 reboot Reboot system/board/card
 summary Display summary information of the device.
 telnet Establish one TELNET connection
 upgrade Upgrade the system boot file, the Boot ROM program or the PoE program
粉丝:11人 关注:0人
看用户模式,截图下报错信息,输入命令注意用户模式
<>sys
