S10508
2022-08-18提问
  • 1收藏,1848浏览
生产环境之前BGP配置里面没有开启balance as-path-relax 现在配上去之前的邻居会有中断重建吗
不会中断,但有可能引起环路、影响流统计
官网原话:
https://techhub.hpe.com/eginfolib/networking/docs/switches/5710/5200-4991_l3-ip-rtng_cr/content/517706813.htm
After this command is executed, BGP ignores the AS_PATH attributes in the routes for load balancing and changes the attributes of the advertised routes to those of the optimal route. This might cause routing loops and affect Netstream statistics. Therefore, use this command with caution.
