MSR3600-20-XS路由器DHCP
2023-03-22提问
  • 0收藏,1986浏览
路由器重启了,然后DHCP突然无法获取地址,但是可以手动设置静态地址连接路由器。
过了两小时之后好像环路了,用静态地址直连也ping不通,并且console连接出现connecting to com3 connected
后卡死。进不去命令行,以下是配置 求助
为什么DHCP会获取不到地址
# version 7.1.064, Release 0809P33
# sysname H3C # clock timezone Beijing add 08:00:00 clock protocol ntp
# telnet server enable
# security-zone intra-zone default permit
# dialer-group 3 rule ip permit
# ip load-sharing mode per-flow src-ip global
# bandwidth-based-sharing
# nat alg sip
# dhcp enable dhcp server always-broadcast
# dns proxy enable # lldp global enable
# password-recovery enable # vlan 1
# dhcp server ip-pool lan1 gateway-list 10.127.20.1 network 10.127.20.0 mask 255.255.255.0
 address range 10.127.20.100 10.127.20.250 dns-list 210.22.84.3 114.114.114.114 forbidden-ip-range 10.127.20.1 10.127.20.1 static-bind
ip-address 10.127.20.96 mask 255.255.255.0 hardware-address 2cea-7fec-b5c8 description ftp-server static-bind
ip-address 10.127.20.97 mask 255.255.255.0 hardware-address 3448-edf7-a5d4 description slave-server static-bind
ip-address 10.127.20.110 mask 255.255.255.0 hardware-address 2848-e796-5f08 description 麦腾天台小机库射频箱路由器 static-bind
ip-address 10.127.20.119 mask 255.255.255.0 hardware-address 5c3a-455b-aaeb static-bind
ip-address 10.127.20.254 mask 255.255.255.0 hardware-address a0c5-f2b3-0301 description OrayVPN
# dhcp server ip-pool smartmc address range 10.127.20.1 10.127.20.254 bootfile-name http://10.127.20.1/web/winet/smartmc.cfg expired unlimited
# controller Cellular0/0
# interface Dialer1 mtu 1492 # interface Dialer2 bandwidth 200000 mtu 1492
 ppp chap password cipher $c$3$vF6D6ydoWsJROe3ca00TGip5y5cdJ8K2lQ==
 ppp chap user 21d311247@wsw ppp ipcp dns admit-any
 ppp ipcp dns request ppp pap local-user 21d311247@wsw password cipher $c$3$o1dr1zODT5qx2YuxjzyLxfGRapaTer83hw==
 dialer bundle enable dialer-group 3 dialer timer idle 0 dialer timer autodial 5
 ip address ppp-negotiate tcp mss 1280 ip last-hop hold nat outbound
# interface NULL0
# interface Vlan-interface1 description LAN-interface
 ip address 10.127.20.1 255.255.255.0 tcp mss 1280
 nat hairpin
enable dhcp server apply ip-pool smartmc ip subscriber l2-connected
enable ip subscriber initiator dhcp
enable ip subscriber initiator unclassified-ip
enable ip subscriber dhcp domain ipoeenabledomain ip subscriber unclassified-ip domain ipoeenabledomain undo smartmc outbound
# interface GigabitEthernet0/0 port link-mode route undo smartmc outbound
# interface GigabitEthernet0/1 port link-mode route description Double_Line1 bandwidth 60000 duplex full speed 100 ip address 140.206.101.116 255.255.255.0 dns server 210.22.84.3 dns server 210.22.70.3 tcp mss 1280 ip last-hop hold
 nat outbound nat outbound 3002
 nat server protocol tcp global current-interface 80 inside 10.0.221.210 9991 description
nat server protocol tcp global current-interface 122 inside 10.127.20.247 3306 description ubantu
 nat server protocol tcp global current-interface 1443 inside 10.127.20.20 443
 nat server protocol tcp global current-interface 1554 inside 10.127.20.253 554 description JINQIAO NVR
 nat server protocol tcp global current-interface 1935 1940 inside 10.127.20.91 1935 1940 description rtmp-rtsp server
 nat server protocol tcp global current-interface 2022 inside 10.127.20.96 80 description qicloud_v3
 nat server protocol tcp global current-interface 5000 5010 inside 10.127.20.20 5000 5010 description Thomas-NAS
 nat server protocol tcp global current-interface 6080 6085 inside 10.127.20.96 6080 6085 description skyscout_test
 nat server protocol tcp global current-interface 7080 inside 10.127.20.96 7080 description 禅道
 nat server protocol tcp global current-interface 8000 inside 10.127.20.98 80
 nat server protocol tcp global current-interface 8081 inside 10.127.20.98 8081 description web
 nat server protocol tcp global current-interface 8082 inside 10.127.20.98 8080 description
nat server protocol tcp global current-interface 8086 inside 10.127.20.98 8086 description http.api
 nat server protocol tcp global current-interface 8087 inside 10.127.20.98 8080
 nat server protocol tcp global current-interface 8089 inside 10.127.20.98 8089 description http-ai-service
 nat server protocol tcp global current-interface 8554 inside 10.127.20.91 554 description 互转互推测试
 nat server protocol tcp global current-interface 8848 inside 10.127.20.96 8848 description zhouqq
 nat server protocol tcp global current-interface 9000 inside 10.127.20.98 9000 description Http-pad-api
 nat server protocol tcp global current-interface 9920 inside 10.127.20.96 8087 description 测试环境socketIO
 nat server protocol tcp global current-interface 9921 inside 10.127.20.96 9921 description zhouqiqi_test
 nat server protocol tcp global current-interface 9922 inside 10.127.20.96 9922 description zhouqq-testv3
 nat server protocol tcp global current-interface 10021 inside 10.127.20.97 10021 description 97 ftp
 nat server protocol tcp global current-interface 10219 inside 10.127.20.98 20219 description 本地化部署权限
 nat server protocol tcp global current-interface 10883 inside 10.127.20.165 1883 description  mqtt
 nat server protocol tcp global current-interface 11883 inside 10.127.20.96 1883 description test_mqtt
 nat server protocol tcp global current-interface 11935 inside 10.127.20.66 1935 description trmp
 nat server protocol tcp global current-interface 12021 inside 10.127.20.98 21 description ftp_server
 nat server protocol tcp global current-interface 12022 inside 10.127.20.96 80 description api_test
 nat server protocol tcp global current-interface 12220 12221 inside 10.127.20.98 12220 12221 description FTP_passive
 nat server protocol tcp global current-interface 13306 inside 10.127.20.98 3306 description test-mysql
 nat server protocol tcp global current-interface 13389 inside 10.127.20.21 3389 description Thomas-PC
 nat server protocol tcp global current-interface 15060 inside 10.127.20.98 15060 description GBS
 nat server protocol tcp global current-interface 16680 inside 10.127.20.66 80 description 拉流地址
 nat server protocol tcp global current-interface 17777 inside 10.127.20.151 8088 description zqq_test_port
 nat server protocol tcp global current-interface 18060 inside 10.127.20.96 8060 description zentao
 nat server protocol tcp global current-interface 18072 inside 10.127.20.242 8072 description 力维测试
 nat server protocol tcp global current-interface 18077 inside 10.127.20.97 7777 description media_test_out
 nat server protocol tcp global current-interface 18080 inside 10.127.20.165 80 description
nat server protocol tcp global current-interface 18081 inside 10.127.20.98 8081 description
nat server protocol tcp global current-interface 18082 inside 10.127.20.98 8082 description qiyun-ai
 nat server protocol tcp global current-interface 18083 inside 10.127.20.98 8083 description web-zhongfei
 nat server protocol tcp global current-interface 18084 inside 10.127.20.98 8084 description ai-test
 nat server protocol tcp global current-interface 18086 inside 10.127.20.97 8999 description hw_server
 nat server protocol tcp global current-interface 18088 inside 10.127.20.97 8088 description qicoud_video
 nat server protocol tcp global current-interface 18089 inside 10.127.20.97 80 description http-images
 nat server protocol tcp global current-interface 18777 inside 10.127.20.109 8777 description
nat server protocol tcp global current-interface 18989 inside 10.127.20.103 8989 description
nat server protocol tcp global current-interface 19086 inside 10.127.20.97 8086 description http-test
 nat server protocol tcp global current-interface 20021 inside 10.127.20.96 21 description 96 ftp
 nat server protocol tcp global current-interface 20215 20219 inside 10.127.20.96 20215 20219 description qicloud_base
 nat server protocol tcp global current-interface 20222 inside 10.127.20.98 7003 description http-missionservice-test
 nat server protocol tcp global current-interface 20225 20229 inside 10.127.20.96 20225 20229 description skyscout-test
 nat server protocol tcp global current-interface 21100 21110 inside 10.127.20.97 21100 21110 description 97FTP被动传输
 nat server protocol tcp global current-interface 21554 inside 10.0.221.5 554 description 机库第三视角
 nat server protocol tcp global current-interface 21555 inside 10.0.221.210 554 description 麦腾第一视角
 nat server protocol tcp global current-interface 21883 inside 10.127.20.96 1883 description TEST_MQTT
 nat server protocol tcp global current-interface 23389 inside 10.127.20.98 3389 description test-server
 nat server protocol tcp global current-interface 28083 inside 10.127.20.96 18083 description TEST_MQTT_WEB
 nat server protocol tcp global current-interface 31100 31110 inside 10.127.20.96 31110 31120 description 96FTP pass
 nat server protocol tcp global current-interface 32022 inside 10.127.20.96 22 description ssh-96
 nat server protocol tcp global current-interface 33306 inside 10.127.20.96 3306 description 96-mysql
 nat server protocol tcp global current-interface 33389 inside 10.127.20.251 3389 description GIS PC
 nat server protocol tcp global current-interface 36379 inside 10.127.20.96 6379 description test-redis
 nat server protocol tcp global current-interface 39922 inside 10.127.20.96 9922 description jenkins
 nat server protocol tcp global current-interface 52022 inside 10.127.20.97 22
 nat server protocol tcp global current-interface 54000 54005 inside 10.127.20.97 4000 4005 description qicloud_ftp_passive
 nat server protocol tcp global current-interface 55521 inside 10.127.20.97 21 description 黄桥站FTP
 nat server protocol tcp global current-interface 55554 inside 10.127.20.210 554 description 无人机
 nat server protocol tcp global current-interface 55555 inside 10.127.20.5 554 description 机库摄像头
 nat server protocol udp global current-interface 15060 inside 10.127.20.98 15060 description GBS-1
 nat server protocol udp global current-interface 30000 30249 inside 10.127.20.98 30000 30249 description rtp-udp
 nat hairpin enable undo smartmc outbound
# interface GigabitEthernet0/2 port link-mode route description Double_Line2 duplex full speed 1000 pppoe-client dial-bundle-number 2 undo smartmc outbound
# interface GigabitEthernet0/27 port link-mode route undo smartmc outbound
# interface GigabitEthernet0/28 port link-mode route undo smartmc outbound
 # interface GigabitEthernet0/3 port link-mode bridge speed 1000 duplex full
# interface GigabitEthernet0/4 port link-mode bridge
# interface GigabitEthernet0/5 port link-mode bridge speed 1000 duplex full
# interface GigabitEthernet0/6 port link-mode bridge duplex full
# interface GigabitEthernet0/7 port link-mode bridge
 # interface GigabitEthernet0/8 port link-mode bridge
# interface GigabitEthernet0/9 port link-mode bridge
# interface GigabitEthernet0/10 port link-mode bridge
# interface GigabitEthernet0/11 port link-mode bridge
# interface GigabitEthernet0/12 port link-mode bridge
# interface GigabitEthernet0/13 port link-mode bridge
# interface GigabitEthernet0/14 port link-mode bridge
# interface GigabitEthernet0/15 port link-mode bridge
# interface GigabitEthernet0/16 port link-mode bridge
 # interface GigabitEthernet0/17 port link-mode bridge
# interface GigabitEthernet0/18 port link-mode bridge
# interface GigabitEthernet0/19 port link-mode bridge
# interface GigabitEthernet0/20 port link-mode bridge
# interface GigabitEthernet0/21 port link-mode bridge
# interface GigabitEthernet0/22 port link-mode bridge
# interface GigabitEthernet0/23 port link-mode bridge
# interface GigabitEthernet0/24 port link-mode bridge
# interface GigabitEthernet0/25 port link-mode bridge
# interface GigabitEthernet0/26 port link-mode bridge
# security-zone name Local
# security-zone name Trust
# security-zone name DMZ
# security-zone name Untrust
# security-zone name Management
# scheduler logfile size 16
# line class console user-role network-admin
# line class tty user-role network-operator
# line class usb user-role network-admin
# line class vty user-role network-operator
# line con 0 user-role network-admin
# line vty 0 63 authentication-mode scheme user-role network-operator
# ip route-static 10.0.221.0 24 Vlan-interface1 10.127.20.246 description 金桥机库内部网络 ip route-static 58.213.14.0 24 GigabitEthernet0/1 140.206.201.115 ip route-static 202.107.201.0 24 10.127.20.3 description 统一视频路由
# ssh server enable
 # ntp-service enable
# password-control enable undo password-control aging enable undo password-control history enable password-control length 6 password-control login-attempt 3 exceed lock-time 10 password-control update-interval 0 password-control login idle-time 0 # domain ipoeenabledomain authentication ipoe none authorization ipoe none accounting ipoe none # domain system # domain default enable system # role name level-0 description Predefined level-0 role
# role name level-1 description Predefined level-1 role
 # role name level-2 description Predefined level-2 role
# role name level-3 description Predefined level-3 role
# role name level-4 description Predefined level-4 role
 # role name level-5 description Predefined level-5 role
 # role name level-6 description Predefined level-6 role
# role name level-7 description Predefined level-7 role
# role name level-8 description Predefined level-8 role
# role name level-9 description Predefined level-9 role
 # role name level-10 description Predefined level-10 role
# role name level-11 description Predefined level-11 role
# role name level-12 description Predefined level-12 role
# role name level-13 description Predefined level-13 role
# role name level-14 description Predefined level-14 role
# user-group system
 # local-user admin class manage service-type telnet http authorization-attribute user-role network-admin
# local-user skysys class manage access-limit 3 service-type ftp service-type ssh telnet terminal http https authorization-attribute user-role network-admin
# session statistics enable
# netconf soap http enable netconf soap https enable
# ip http port 18000 ip http enable web new-style
# url-filter category custom severity 65535 # smartmc tm username skysys password cipher $c$3$ipDs+uNiX7YJWLAmddOjCNmrNhLx7P6I9KIKvA== enable smartmc topology-refresh interval 60 smartmc backup configuration max-number 5 undo smartmc backup configuration interval undo smartmc auto-replace enable smartmc resource-monitor interval 1 smartmc resource-monitor max-age 24 undo smartmc auto-link-aggregation enable
# wlan global-configuration
# wlan ap-group default-group vlan 1
# dac storage service traffic limit hold-time 1
# cloud-management server domain oasis.h3c.com # return
1212 八段
粉丝:8人 关注:6人
串口登不进去就不对劲,那个时候除了ping不通还有啥别的现象吗
所有接口网线灯闪烁一致
zhiliao_kpKTq2 发表时间:2023-03-22 更多>>
所有接口网线灯闪烁一致
呵呵 九段
粉丝:29人 关注:0人
路由器作为DHCP客户端无法获取到地址吗,哪个接口
所有接口
所有接口
粉丝:64人 关注:2人
串口应该是能进去,但是命令敲不上,可能是CPU 100%
另外你的说所有灯同时闪,可能就是环路的了,把网线拔一下,看恢复没有,之后再去找环路的问题
