交换机压测
2024-04-07提问
  • 0收藏,1911浏览
粉丝:0人 关注:2人
如何利用端口镜像测试交换机上行端口最大带宽
佚名 九段
粉丝:25人 关注:0人
一般需要专业的打流工具,或者服务器打流,如果是镜像的话,只要流量足够多,目的口肯定能打满的,但这种测试没有意义
您好,看不了,直接用命令看进行规避
display  interface Ten-GigabitEthernet5/0/1
Current state: UP
Line protocol state: UP
Description: Ten-GigabitEthernet5/0/1 Interface
Bandwidth: 10000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Internet address: 80.1.1.2/24 (primary)
IP packet frame type: Ethernet II, hardware address: 9ce8-9572-a152
IPv6 packet frame type: Ethernet II, hardware address: 9ce8-9572-a152
Loopback is not set
Media type is stack wire, port hardware type is STACK_SFP_PLUS
Port priority: 0
10Gbps-speed mode, full-duplex mode
Flow-control is not enabled
The maximum frame length is 10000
Last link flapping: 22 hours 49 minutes 36 seconds
 Peak input rate: 842 bytes/sec, at 2019-08-02 01:45:15
 Peak output rate: 841 bytes/sec, at 2019-08-02 01:45:15
 Last 300 second input: 0 packets/sec 28 bytes/sec 0%   /// 过去300秒的平均带宽利用率
 Last 300 second output: 0 packets/sec 27 bytes/sec 0%
 Input (total):  146268 packets, 11680083 bytes
         134971 unicasts, 10 broadcasts, 11287 multicasts, 0 pauses
 Input (normal):  146268 packets, - bytes
         0 CRC, 0 frame, - overruns, 0 aborts
         - ignored, - parity errors
 Output (total): 162878 packets, 12752975 bytes
         151613 unicasts, 6 broadcasts, 11259 multicasts, 0 pauses
 Output (normal): 162878 packets, - bytes
         0 lost carrier, - no carrier
那也需要流量才行
可以使用者专业的打流量工具测试测试
镜像实现不了
