mac-vlan用处
2018-11-26提问
  • 2收藏,2492浏览
请问在服务模板下配置mac-vlan enable的作用是什么,mac-vlan这个的介绍麻烦也给个链接学习下,谢谢
粉丝:116人 关注:0人
就是三层漫游的时候需要开的,这样能实现客户端漫游时vlan保持不变。
V5的控制器如果需要一个服务模板绑定多个van都是必开的。
  1. 实验拓扑
  2. 实验需求
实现不同AP下联的属于相同SSID不同vlan的无线终端用户实现漫游。
  1. 实验配置
1、WX5540E AC板配置:
vlan 20 to 22
dhcp server ip-pool vlan20
 network 192.168.20.0 mask 255.255.255.0
 gateway-list 192.168.20.1
dhcp server ip-pool vlan21
 network 192.168.21.0 mask 255.255.255.0
 gateway-list 192.168.21.1
dhcp server ip-pool vlan22
 network 192.168.22.0 mask 255.255.255.0
 gateway-list 192.168.22.1
wlan service-template 200 clear
 ssid GDJ
 bind WLAN-ESS 200
 service-template enable
#配置各VLAN的网关地址
interface Vlan-interface20
 ip address 192.168.20.1 255.255.255.0
interface Vlan-interface21
 ip address 192.168.21.1 255.255.255.0
interface Vlan-interface22
 ip address 192.168.22.1 255.255.255.0
interface Bridge-Aggregation1
 port link-type trunk
 port trunk permit vlan all
interface WLAN-ESS200
 port link-type hybrid
 undo port hybrid vlan 1
 port hybrid vlan 20 untagged
 port hybrid pvid vlan 20
 mac-vlan enable
wlan ap xhy model WA2620X id 1
 priority level 6
 serial-id 219801A0KTM144001504
 radio 1
 radio 2
  service-template 200 vlan-id 21
  radio enable
wlan ap xhy2 model WA2620i-AGN id 2
 serial-id 219801A0CMC146000765
 radio 1
 radio 2
  service-template 200 vlan-id 22
  radio enable
 dhcp enable
2、接入POE交换机配置
 port access vlan 20
 poe enable
 port access vlan 20
 poe enable
 port access vlan 20
 poe enable
3、AC交换板配置:
#配置与POE交换机相连的接口
interface GigabitEthernet1/0/5
 port access vlan 20
  1. 实验配置
使用AP连接到SSID:GDJ上,查看此时获取到的IP地址是属于那个VLAN的:
获取到的为VLAN22的地址
[WX5540E-1]dis wlan client
 Total Number of Clients           : 1
                              Client Information
 SSID: GDJ
MAC Address    User Name            APID/RID IP Address      IPv6 Address   VLAN
400e-8574-da1d -NA-                 1   /2   192.168.22.11   -NA-           22
[WX5540E-1]dis wlan client verbose
                              Client Information
 MAC Address                       : c033-5ee0-dca3
 User Name                         : -NA-
 IP Address                        : 192.168.21.11
 IPv6 Address                      : -NA-
 AID                               : 1
 AP Name                           : xhy
 Radio Id                          : 2
 Antenna Id                        : 0
 Service Template Number           : 200
 SSID                              : GDJ
 BSSID                             : 5cdd-709a-82f0
 Port                              : WLAN-DBSS200:0
 VLAN                              : 21
 State                             : Running
 Power Save Mode                   : Sleep
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Not Supported
 LDPC                              : Not Supported
 STBC TX capability                : Not Supported
 STBC RX capability                : Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7,8,9,
                                     10,11,12,13,14,15
 BLOCK ACK-TID 0                   : BOTH
 BLOCK ACK-TID 1                   : OUT
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 42
 Rx/Tx Rate                        : 78/104
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 Authentication Mode               : Central
 AKM Method                        : None
 Key Derivation                    : -NA-
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 PMF Status                        : -NA-
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:03:08
 Bonjour Records                   :
此时由于wa2620i-AGN的信号过强,无法实现漫游,手工关闭wa2620i-AGN的射频口触发终端漫游
[WX5540E-wlan-ap-xhy2-radio-2]radio disable
终端没有掉线,无缝切换到WA2620X的射频上。
查看此时的客户端状态:
[WX5540E-1]          dis wlan client
                              Client Information
 SSID: GDJ
c033-5ee0-dca3 -NA-                 2   /2   192.168.21.11   -NA-           21
                              Client Information
 User Name                         : -NA-
 IPv6 Address                      : -NA-
 AID                               : 1
 AP Name                           : xhy2
 Radio Id                          : 2
 Antenna Id                        : 0
 SSID                              : GDJ
 BSSID                             : 70f9-6daf-ee10
 Port                              : WLAN-DBSS200:1
 VLAN                              : 21
 State                             : Running
                                     10,11,12,13,14,15
 QoS Mode                          : WMM
 RSSI                              : 53
 Rx/Tx Rate                        : 1/1
 AKM Method                        : None
 PMF Status                        : -NA-
 Roam Status                       : Intra-AC roam association   //有进行漫游
 Roam Count                        : 1
 Up Time (hh:mm:ss)                : 00:00:11
 Bonjour Records                   :
查看客户端漫游记录:
<WX5540E-1>dis wlan client roam-track mac-address c033-5ee0-dca3
 BSSID          Online-time(d:h:m:s) AC-IP-address
 70f9-6daf-ee10 0000:00:01:40        0.0.0.0 (HOME AC)
 5cdd-709a-82f0 0000:00:03:41        0.0.0.0 (HOME AC)
有相应的漫游记录。
