Print
知
S7506X 收到大量arp导致 CPU高
2024-08-23 发表
组网及说明
设备做终端的网关
告警信息
ARP/5/ARP_PACKET_SPEEDLIMIT_ALARM: -MDC=1-Slot=0; ARP or ARP miss packets were sent at 802 pps, which exceeded the alarm threshold.
S7506X_OLT DRVPLAT/4/SOFTCAR DROP: -Slot=0;
 PktType= ARP , srcMAC=0200-004a-67b2,Drop From Interface=Olt0/0/9     at Stage=7, StageCnt=381959, TotalCnt=1135172
问题描述
设备业务异常,终端不定时获取不到地址
slot0的cpu异常高,正常时不到10%
[OLT-probe]display  cpu-usage
Slot 0 CPU 0 CPU usage:
      70% in last 5 seconds
      70% in last 1 minute
      69% in last 5 minutes
Slot 1 CPU 0 CPU usage:
       6% in last 5 seconds
       7% in last 1 minute
       8% in last 5 minutes
过程分析
[OLT]monitor process slot  0   //看到收包和arp相关进程高
290 processes; 318 threads; 593 fds
Thread states: 6 running, 312 sleeping, 0 stopped, 0 zombie
CPU states: 0.02% idle, 4.23% user, 77.96% kernel, 17.79% interrupt
Memory: 976M total, 344M available, page size 4K
    JID    PID  PRI  State  FDs    MEM  HH:MM:SS    CPU   Name
    187    187  120    R     0      0K  01:24:58  41.96%  [T_RT]
    206    206  115    R     0      0K  00:38:55  16.07%  [bRX1]
    346    346  115    R     0      0K  00:37:56  13.09%  [karp/1]
    270    270  120    R    22  12352K  00:06:35   6.39%  diagd
    198    198  111    D     0      0K  00:08:46   4.01%  [SC_CORE]
     34     34  100    D     0      0K  00:04:32   3.27%  [RECV]
      1      1  120    S    17  10432K  00:00:22   2.52%  scmd
     93     93  115    D     0      0K  00:03:15   2.08%  [PRSC]
     61     61  116    D     0      0K  00:01:53   1.63%  [bLK0]
    204    204  120    D     0      0K  00:02:30   1.63%  [SCAR]
解决方法
debug rxtx softcar show slot 0 看上cpu是否有丢包
ID  Type                RcvPps Rcv_All    DisPkt_All Pps  Dyn Swi Hash ACLmax
29  ARP                 1211   13623388   725999     750  S   On  SMAC 8
限速750pps  ,每秒1211,导致超过限速丢包
cpu高主要是arp报文冲击cpu引起的。
Probe视图执行下述命令,看看arp报文主要从哪个端口上来的,看看是否存在arp攻击
debug rxtx softcar 29 portdetail slot 0
可以看出各个接口arp报文收到的速度,确认是哪个接口收到异常大量的arp
[_S7506X_OLT-probe]debug rxtx softcar 29 portdetail slot 0
 Softcar Type  ARP  PortStatusFetchCnt=11112
Port  Level  Attkd_time  Packet/s  DisPkt/s  Pack_tol  DisP_tol  Pps/P  Proprtn
0     0      0           0         0         25077     0         750    0  1  0
1     1      0           101       0         6074272   166723    750    0  1  0
2     0      0           0         0         15999     0         750    0  1  0
3     0      0           0         0         0         0         750    0  1  0
4     0      0           0         0         783       0         750    0  1  0
5     0      0           0         0         0         0         750    0  1  0
6     0      0           0         0         4685      0         750    0  1  0
7     0      0           0         0         0         0         750    0  1  0
8     5      -9          475       0         7576769   564567    750    1  1  1
9     0      0           0         0         1866      0         750    0  1  0
10    0      0           0         0         0         0         750    0  1  0
Port 8对应port maping 的name ge8 对应olt0/0/9
Port1 对应 port maping的 name ge1 对应0/0/2
[RHWGY_CORE_S7506X_OLT-probe]debug  port mapping slot 0
[Interface]   [Unit]  [Port] [Name] [Combo?] [Active?] [IfIndex]  [MID]   [Link]
 OLT0/0/1         0     1     ge0      no        no      0x1         4      up
 OLT0/0/2         0     2     ge1      no        no      0x2         4      up
 OLT0/0/3         0     3     ge2      no        no      0x3         4      up
 OLT0/0/4         0     4     ge3      no        no      0x4         4      down
 OLT0/0/5         0     5     ge4      no        no      0x5         4      up
 OLT0/0/6         0     6     ge5      no        no      0x6         4      down
 OLT0/0/7         0     7     ge6      no        no      0x7         4      up
 OLT0/0/8         0     8     ge7      no        no      0x8         4      up
 OLT0/0/9         0     9     ge8      no        no      0x9         4      up
 OLT0/0/10        0     10    ge9      no        no      0xa         4      up
 OLT0/0/11        0     11    ge10     no        no      0xb         4      up
 OLT0/0/12        0     12    ge11     no        no      0xc         4      up
 OLT0/0/13        0     13    ge12     no        no      0xd         4      up
这两个接口收到大量arp导致cpu高
使用如下功能防护
源MAC地址固定的ARP攻击检测功能简介
本特性根据ARP报文的源MAC地址对上送CPU的ARP报文进行统计,在5秒内,如果收到同一源MAC地址(源MAC地址固定)的ARP报文超过一定的阈值,则认为存在攻击,系统会将此MAC地址添加到攻击检测表项中。当开启了ARP日志信息功能(配置arp source-mac log enable命令),且在该攻击检测表项老化之前,如果设置的检查模式为过滤模式,则会打印日志信息并且将该源MAC地址发送的ARP报文过滤掉,同时,还会将源/目的MAC地址为该MAC地址的数据报文也过滤掉;如果设置的检查模式为监控模式,则只打印日志信息,不会将该源MAC地址发送的ARP报文过滤掉。关于ARP日志信息功能的详细描述,请参见“三层技术-IP业务配置指导”中的“ARP”。
切换源MAC地址固定的ARP攻击检查模式时,如果从监控模式切换到过滤模式,过滤模式马上生效;如果从过滤模式切换到监控模式,已生成的攻击检测表项,到表项老化前还会继续按照过滤模式处理。
对于网关或一些重要的服务器,可能会发送大量ARP报文,为了使这些ARP报文不被过滤掉,可以将这类设备的MAC地址配置成保护MAC地址,这样,即使该设备存在攻击也不会被检测或过滤。
# 开启源MAC地址固定的ARP攻击检测功能,并选择filter检查模式。
<Sysname> system-view
[Sysname] arp source-mac filter
