Print
知
某局点 WX3540X Windows系统802.1x认证失败
2024-08-29 发表
组网及说明
WX3540X,Version 9.1.055, Release 1218P01
问题描述
现场AC和IMC做了远程802.1X认证,使用手机认可以证成功,电脑用iNode客户端输入用户名和密码可以认证成功,但是使用Windows自带的连接输入用户名和密码提示:无法连接到这个网络
过程分析
一、看AC日志有如下信息,第一次认证是带了host名称,所以提示服务器上用户不存在,第二次认证的时候,没有带host名称,还是认证失败了,提示:A user failed 802.1X authentication.Reason:AAA processed authentication request and return 26.
根据之前的一些案例,设置Windows上终端网卡为用户身份验证,还是不行
DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=host/aaaaaaaaa-UserMAC=xxxx-xxxx-xxxx-BSSID=zzzz-xxxx-xxxx-SSID=Name-APName=AP-RadioID=1-VLANID=32; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 26. Server reason "E63018: The user does not exist or has not subscribed to this service."
DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=test-UserMAC=xxxx-xxxx-xxxx-BSSID=zzzz-zzzz-xxxx-SSID=Name-APName=AP-RadioID=2-VLANID=32; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 26.
二、在AC上debugging radius all,有如下信息,03代表服务器回复Access-Reject认证拒绝,联系IMC侧同事协助分析
*Aug  1 18:23:36:468 2024 H3C-AC-TEST RADIUS/7/PACKET:
    EAP-Message=0x04090004
    Message-Authenticator=0x66bab01c041290651e8abc8dc34c3503
 03 8a 00 2c 45 4c c8 52 b5 94 38 93 a2 36 10 a9
 7f ee 9c b6 4f 06 04 09 00 04 50 12 66 ba b0 1c
 04 12 90 65 1e 8a bc 8d c3 4c 35 03
*Aug  1 18:23:36:468 2024 H3C-AC-TEST RADIUS/7/EVENT: Sent reply message successfully.
*Aug  1 18:23:36:468 2024 H3C-AC-TEST RADIUS/7/EVENT: PAM_RADIUS: Processing RADIUS authentication.
*Aug  1 18:23:36:468 2024 H3C-AC-TEST RADIUS/7/EVENT: PAM_RADIUS: Fetched authentication reply-data successfully, resultCode: 1
%Aug  1 18:23:36:468 2024 H3C-AC-TEST DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=xxxx-UserMAC=xxxx-xxxx-xxxx-BSSID=xxxx-xxxx-xxxx-SSID=Name-APName=AP-RadioID=2-VLANID=32; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 26.
解决方法
最后IMC侧排查,EIA预置证书过期,重新导入证书后认证成功
