Print
知
【MVS】SQLSERVER如何完整备份恢复
15小时前 发表
问题描述
SQLSERVER如何完整备份恢复
解决方法
示例完整数据库备份、结尾日志备份。随后示例还原完整数据库备份和日志备份、还原结尾日志备份,最后恢复数据库。
USE master;
GO
ALTER DATABASE AdventureWorks2022 SET RECOVERY FULL;
GO
-- Back up the AdventureWorks2022 database to new media set (backup set 1).
BACKUP DATABASE AdventureWorks2022
  TO DISK = 'Z:\SQLServerBackups\AdventureWorks2022FullRM.bak'
  WITH FORMAT;
### 需测试;
--Create a differential database backup.  差异备份;
TO DISK = 'Z:\SQLServerBackups\AdventureWorks2022.bak'
   WITH DIFFERENTIAL;
GO
GO
--Create a routine log backup (backup set 2). 备份事务日志
BACKUP LOG AdventureWorks2022 TO DISK = 'Z:\SQLServerBackups\AdventureWorks2022FullRM.bak';
GO
USE master;
--Create tail-log backup. 备份结尾日志;
TO DISK = 'Z:\SQLServerBackups\AdventureWorksFullRM.bak'
   WITH NORECOVERY, NO_TRUNCATE;
GO
--Restore the full database backup (from backup set 1).  还原数据库备份或差异备份
RESTORE DATABASE AdventureWorks2022
  FROM DISK = 'Z:\SQLServerBackups\AdventureWorksFullRM.bak'
  WITH FILE=1,
    NORECOVERY;
--Restore the regular log backup (from backup set 2).  还原事务日志
RESTORE LOG AdventureWorks2022
  WITH FILE=2,
    NORECOVERY;
--Restore the tail-log backup (from backup set 3).  还原结尾日志
  WITH FILE=3,
    NORECOVERY;
GO
--recover the database:
RESTORE DATABASE AdventureWorks2022 WITH RECOVERY;
GO
