Print
知
【MVS】MySQL创建指定目录下表空间报错ERROR 3121 (HY000):
2024-10-25 发表
问题描述
## 创建表空间报错
mysql> CREATE TABLESPACE my_general_tbs16k
    ->     ADD DATAFILE '/data/dbfile/my_general_tbs16k1.ibd'
    ->     FILE_BLOCK_SIZE = 16384
    ->     ENGINE = InnoDB;
ERROR 3121 (HY000): The DATAFILE location must be in a known directory.
解决方法
## 创建表空间报错,是因为没有在参数文件中设置可信目录。
    ->     ENGINE = InnoDB;
如需创建mysql指定目录表,则需在参数中设置目录,或启动时临时设置。
参数文件永久设置:MySQL option file:
[mysqld]
innodb_directories="directory_path_1;directory_path_2"
注意:建议关闭实例设置参数,后启动校验。
或在启动临时设置:Startup command:
mysqld --innodb-directories="directory_path_1;directory_path_2"
### 在配置文件中修改参数,后重启实例,查看参数配置情况
mysql> show variables like '%innodb_directories%';
| Variable_name      | Value        |
| innodb_directories | /data/dbfile |
1 row in set (0.01 sec)
mysql>
##创建指定目录表空间
ENGINE = InnoDB;
# 查询表空间情况
mysql> SELECT TABLESPACE_NAME, FILE_NAME FROM INFORMATION_SCHEMA.FILES;
| TABLESPACE_NAME          | FILE_NAME                           |
| abc/my_independent_table | ./abc/my_independent_table.ibd      |
| abc/t1                   | ./abc/t1.ibd                        |
| employees/departments    | ./employees/departments.ibd         |
| employees/dept_emp       | ./employees/dept_emp.ibd            |
| employees/dept_manager   | ./employees/dept_manager.ibd        |
| employees/employees      | ./employees/employees.ibd           |
| employees/salaries#p#p01 | ./employees/salaries#p#p01.ibd      |
| innodb_undo_001          | ./undo_001                          |
| innodb_undo_002          | ./undo_002                          |
| my_general_space         | ./my_general_space.ibd              |
| my_general_tbs16k        | /data/dbfile/my_general_tbs16k1.ibd |
| mysql                    | ./mysql.ibd                         |
| mysql/backup_history     | ./mysql/backup_history.ibd          |
| mysql/backup_progress    | ./mysql/backup_progress.ibd         |
| sys/sys_config           | ./sys/sys_config.ibd                |
54 rows in set (0.00 sec)
#创建表并插入数据测试
mysql> CREATE TABLE tab1_gtbs (c1 INT PRIMARY KEY) TABLESPACE my_general_tbs16k;
mysql> insert into tab1_gtbs ('1');
mysql> INSERT INTO tab1_gtbs (c1) VALUES (1);
mysql> commit;
mysql> select * from tab1_gtbs;
| c1 |
|  1 |
备注:
innodb 表空间不能设置最大大小,是由文件系统决定的。
