Print
知
【MVS】openEuler 中执行yum命令报错SSL certificate problem: unable to get local issuer certificate
2024-10-28 发表
问题描述
系统版本:
openEuler 24.03 (LTS)
6.6.0-28.0.0.34.oe2403.x86_64
问题概述:
执行 yum makecache提示如下错误,检查网页路径无问题;
# yum makecache
OS        0.0  B/s |   0  B     00:00
Errors during downloading metadata for repository 'OS':
  - Curl error (60): SSL peer certificate or SSH remote key was not OK for https://mirrors.XXX.com/openeuler/openEuler-24.03-LTS/OS/x86_64/repodata/repomd.xml [SSL certificate problem: unable to get local issuer certificate]
Error: Failed to download metadata for repo 'OS': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
解决方法
解决办法:
关闭 SSL Verification  (生产环境不建议修改):
# vim /etc/yum.conf
添加 sslverify=false
修改后测试:
重新执行yum makecache正常。
# yum makecache
OS        3.4 MB/s | 2.9 MB     00:00
everything        14 MB/s |  16 MB     00:01
EPOL        4.1 MB/s | 4.3 MB     00:01
debuginfo        4.0 MB/s | 4.4 MB     00:01
source        2.3 MB/s | 1.7 MB     00:00
update        6.9 MB/s |  15 MB     00:02
update-source        790 kB/s | 541 kB     00:00
Metadata cache created.
