Print
知
阻断dot1x报文的方法
2024-10-30 发表
问题描述
现场由于dot1x报文过多,导致现场交换机的pon芯片负载过高业务异常,需要先把dot1x报文先丢弃恢复业务
过程分析
目前看到slot10的pon芯片都发生了多次updown
  ====dis hardware internal epon olt chipstatus chassis 1 slot 10 chip 0====
    CHIPID    STATUS    DOWN_CNT    UP_CNT    LOAD_CNT    CHIP_GEMODE
      0       UP           34         81        47         0
  ====dis hardware internal epon olt chipstatus chassis 1 slot 10 chip 1====
      1       UP           35         60        26         0
  ====dis hardware internal epon olt chipstatus chassis 1 slot 10 chip 2====
      2       UP           35         61        26         0
而且slot 10单板的SC_Q_CORE队列已经满了,出现队列put_error丢包。
  ======display hardware internal epon global-variable chassis 1 slot 10=====
Compatible:1, EncryptUpdateTime:10, EoamTimeOut:80, AutoBindMode:1-01
cfgtimes:7035, cfgspendtime:6040312s
OnuRegRecCount:4000, OnuRegCurIndex:689
SampleCycle:4, SampleEnable:1, MonitorCycle:80, MonitorEnable:1
StatTimerId:38, StatTimerCnt:58303, StatEnable:0
DHCPGlobalEnable:4, StpGlobalEnable:1
DrvRxEoam:672, RxEoamErr:0, RxEoamNotSupport:0
EponInitIsOK: 1, Rx illegal OAM cnt: 0-672-0-0
Global dba:100
EponNonStdMac:1
EponIsClearNonStdMac:0
SDK queue info:
Id:0, name:SC_Q_CORE, queuesize:8, depth:4096, cur_num:0
  max_num:4096, peek_value:0, put_error:2393675, put_full_error:0
  put_timeout_error:0, put_data_error:0, put_data_long:0
Id:1, name:SC_Q_TX, queuesize:8, depth:4096, cur_num:0
  max_num:8, peek_value:0, put_error:0, put_full_error:0
怀疑是大量的dot1x报文冲击的olt的pon芯片,造成pon芯片updown。
建议在与olt相连的核心设备的聚合口配置包过滤,把dot1x(0x888e)报文丢掉。
解决方法
acl number 4001
rule 0 permit type 888e ffff
traffic classifier test
if-match acl 4001
traffic behavior test
accounting packet
filter deny
qos policy test
classifier test behavior test
int Bridge-Aggregation 50
qos apply policy test outboumd
qos apply policy test inbound
