Print
知
某局点 S6805-56HF-G 告警分析 Continous packet loss no longer detected on protocol message queue 125
2025-02-05 发表
组网及说明
不涉及
告警信息
%Jan 17 05:32:39:176 2025  DRVPLAT/4/SOFTCAR DROP:
 Chip=0, Cos=125, Drop at Stage=0, StageCnt=9691, TotalCnt=9691, possible protocol TTL_FAIL/MTU_FAIL/URPF_FAIL/RARP
%Jan 17 05:32:39:176 2025  DEV/4/BOARD_WARNING_OCCUR: Board warning alarm occurred. (PhysicalIndex=173, PhysicalName=Board, RelativeResource=(chiptype:Switch Chip,chassis:1,slot:1,chipid:0,channel:125), ErrorCode=423038, Reason=Continuous packet loss detected on the queue of protocol messages from the switch chip to the CPU. Queue=125, Stage=0, StageCnt=9691, TotalCnt=9691, Possible protocols=TTL_FAIL/MTU_FAIL/URPF_FAIL/RARP)
%Jan 17 05:42:42:414 2025  DRVPLAT/4/SOFTCAR DROP:
 Chip=0, Cos=125, Drop at Stage=0, StageCnt=28786, TotalCnt=38477, possible protocol TTL_FAIL/MTU_FAIL/URPF_FAIL/RARP
%Jan 17 05:52:45:707 2025  DRVPLAT/4/SOFTCAR DROP:
 Chip=0, Cos=125, Drop at Stage=0, StageCnt=28336, TotalCnt=66813, possible protocol TTL_FAIL/MTU_FAIL/URPF_FAIL/RARP
%Jan 17 06:02:48:827 2025  DRVPLAT/4/SOFTCAR DROP:
 Chip=0, Cos=125, Drop at Stage=0, StageCnt=961, TotalCnt=67774, possible protocol TTL_FAIL/MTU_FAIL/URPF_FAIL/RARP
%Jan 17 09:03:47:447 2025 DRVPLAT/4/SOFTCAR RECOVER:  Chip=0 Cos=125
%Jan 17 09:03:47:447 2025  DEV/4/BOARD_WARNING_CLEAR: Board warning alarm cleared. (PhysicalIndex=173, PhysicalName=Board, RelativeResource=(chiptype:Switch Chip,chassis:1,slot:1,chipid:0,channel:125), ErrorCode=423038, Reason=Continous packet loss no longer detected on protocol message queue 125.)
问题描述
cos125队列上cpu持续丢包
过程分析
某局点 S7800XPG 下挂同网段终端ping测试丢首包 - 知了社区
参考此方法,发现TTL_FAIL  有丢包记录
  ===============display hardware internal rxtx softcar show slot 1===============
SoftCar limit rate info
Id   Type                     ReasonId QueueId ReasonRcvAll ReasonRcvPps Pps
62   TTL_FAIL                 79       125     175758889    0            100
 ===============display hardware internal rxtx coscar show slot 1===============
CosCar limit rate info
Index    RcvPktAll       RcvPktPps      DisPktAll    DisPktPps   Pps
125      175758886       0              57637256     0           100
将cos125打印出来看都是ttl=1的报文
probe
dis rxtx cos 125 slot x
undo dis rxtx send slot x
dis rxtx switchflag slot x
debugging driver notice slot x
debug rxtx -c 100 -s 256 pkt slot x
return
t d
t m
从打印的信息能看到这些ttl=1的报文都是那个接口进来的
[2025-01-22 18:20:25]    *Jan 22 18:20:25:171 2025 DRVPLAT/7/RxTxDebug:
[2025-01-22 18:20:25]     driver rx:lchip=0, queue=125,reason=79,len=60,gchip=0,flag=0x1,src logicport 0, fid 0,
[2025-01-22 18:20:25]    *Jan 22 18:20:25:171 2025 HZ-TL-M204PROD-B01-H3C-S6805-WC-1 DRVPLAT/7/RxTxDebug:
[2025-01-22 18:20:25]     bridge header: 00 04 01 f5 00 aa 00 04 80 06 02 78 00 10 08 09 80 40 00 00 00 00 80 26 e3 49 44 80 14 00 70 00 00 00 00 00 0
[2025-01-22 18:20:25]    From board 1: received packet from chip0,port9,reason=0x4f,cos=125,gslot=0,len=60,Matched=0,time: s=0, ns=0, dstgchip=0, dstLport=0
[2025-01-22 18:20:25]     -----------------------------------------------------
[2025-01-22 18:20:25]     0000  ac ce 92 7c 0c 0e 7c de 78 25 ba 01 08 00 45 00
[2025-01-22 18:20:25]     0010  00 2c d4 31 00 00 01 06 7d 09 8f 2a 01 d5 73 e7
[2025-01-22 18:20:25]     0020  63 ab 99 f2 15 ff b5 8b 74 dc 00 00 00 00 60 02
[2025-01-22 18:20:25]     0030  ff ff 55 3b 00 00 02 04 05 b4 00 00
[2025-01-22 18:20:25]     Rx To Platform:p1=0,p2=1, p3=0x3, p4=60,p5=0, p6=ffffff8001fc24f8, p7=65, P8=0, P9=79, P10=1, P11=0
[2025-01-22 18:20:25]    *Jan 22 18:20:25:568 2025 HZ-TL-M204PROD-B01-H3C-S6805-WC-1 DRVPLAT/7/RxTxDebug:
[2025-01-22 18:20:25]     bridge header: 00 04 01 f5 00 38 00 04 00 06 02 78 00 10 08 0a 00 40 00 00 00 00 80 22 e6 3f 90 e8 14 06 40 20 00 00 00 00 0
[2025-01-22 18:20:25]    *Jan 22 18:20:25:568 2025  DRVPLAT/7/RxTxDebug:
[2025-01-22 18:20:25]    From board 1: received packet from chip0,port8,reason=0x4f,cos=125,gslot=0,len=60,Matched=0,time: s=0, ns=0, dstgchip=0, dstLport=0
[2025-01-22 18:20:25]     0000  ac ce 92 7c 0c 0e 7c de 78 25 ba 01 08 00 45 08
[2025-01-22 18:20:25]     0010  00 2c 4f 12 00 00 01 06 a2 c6 c1 a3 7d f7 7b 94
[2025-01-22 18:20:25]     0020  0c bd a2 ce 06 e2 1e f9 eb 31 00 00 00 00 60 02
[2025-01-22 18:20:25]     0030  39 08 e3 56 00 00 02 04 05 b4 00 00
从打印的信息能看出是从1/0/1 和1/0/2进来的ttl=1的报文
解决方法
排除对端为什么发来这些ttl=1的报文
