Print
知
CR16010H-F 删除静态会话报错
2025-02-27 发表
问题描述
设备CR16K做BRAS,原本在808接口上配置了静态会话:
interface Route-Aggregation1.808
 ip subscriber session static ip 172.X.X.X 172.Y.Y.Y
使用一段时间后需要做变更,在删除静态会话时有报错:
undo ip subscriber session static ip 172.X.X.X 172.Y.Y.Y
Operation failed. Cannot delete or modify static session configuration because online static users exist.
过程分析
需要先删除静态会话表项才能删除此命令。
旧版本删除的命令为reset ip subscriber session
现场设备版本为8530Pxx的,新版本没有这条命令,可以使用cut access-user删除用户会话:
cut access-user ?
  auth-type          Specify a user by authentication type
  domain             Specify users by ISP domain
  interface          Specify users by interface
  ip-address         Specify a user by IPv4 address
  ip-pool            Specify users by an IP pool
  ip-type            Specify users by IP type
  ipv6-address       Specify a user by IPv6 address
  ipv6-pool          Specify users by an IPv6 pool
  ipv6-prefix        Specify users by IPv6 address prefix
  mac-address        Specify a user by MAC address
  slot               Specify the slot number
  user-address-type  Specify users by address type
  user-id            Specify a user by user ID
  user-profile       Specify users by user profile
  username           Specify a user by username
  vpn-instance       Specify a VPN instance
  vxlan              Specify users by a range of VXLANs
  <cr>
现场需要删除多个IP,可以手动创建一个地址池,包括这些需要删除会话的IP,然后使用cut access-user ip-pool XXX来批量删除表项。
解决方法
使用cut access-user删除相关表项后可以正常删除静态会话。
