Print
知
SR8816-X无法读取子接口流量信息
20小时前 发表
组网及说明
不涉及
告警信息
不涉及
问题描述
客户局点设备读取如下节点信息,无法读取,返回值是0,
1.3.6.1.2.1.4.31.3.1.1
1.3.6.1.2.1.4.31.3.1.2
1.3.6.1.2.1.4.31.3.1.5
1.3.6.1.2.1.4.31.3.1.6
过程分析
如下四个节点读取信息异常,之前建议现场升级83版本,升级之后还是读取不到信息,实验室使用SR8802-X-S,版本Release 8530P10,和客户测试现象类似,
前两个节点,本地读取如下提示,
[root@localhost ~]# snmpwalk -v 2c -c hzlabread 10.88.142.124 1.3.6.1.2.1.4.31.3.1.1
IP-MIB::ipIfStatsIPVersion = No Such Object available on this agent at this OID
[root@localhost ~]# snmpwalk -v 2c -c hzlabread 10.88.142.124 1.3.6.1.2.1.4.31.3.1.2
IP-MIB::ipIfStatsIfIndex = No Such Object available on this agent at this OID
后面两个节点读取,所有索引返回都是空,现场读取也是类似情况,请帮忙确认一下这几个节点是不支持还是读取的有问题,谢谢!
[root@localhost ~]# snmpwalk -v 2c -c hzlabread 10.88.142.124 1.3.6.1.2.1.4.31.3.1.5
IP-MIB::ipIfStatsInOctets.ipv4.385 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.386 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.387 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.388 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.389 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.390 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.391 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.392 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.393 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17665 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17796 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17797 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17798 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17799 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17800 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17801 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.17802 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.385 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.386 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.387 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.388 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.389 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.390 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.391 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.392 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.393 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17665 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17796 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17797 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17798 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17799 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17800 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17801 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.17802 = Counter32: 0
[root@localhost ~]# snmpwalk -v 2c -c hzlabread 10.88.142.124 1.3.6.1.2.1.4.31.3.1.6
IP-MIB::ipIfStatsHCInOctets.ipv4.385 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.386 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.387 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.388 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.389 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.390 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.391 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.392 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.393 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17665 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17796 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17797 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17798 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17799 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17800 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17801 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.17802 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.385 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.386 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.387 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.388 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.389 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.390 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.391 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.392 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.393 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17665 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17796 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17797 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17798 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17799 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17800 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17801 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.17802 = Counter64: 0
解决方法
所有接口/子接口下要使能statistics l3-packet enable,才能正常读取。
