Print
知
[MVS]kingbase 基于时间的不完全恢复
7小时前 发表
配置步骤
--1、查看备份集信息。
[kingbase@kesv9 kingbase]$  sys_rman --cOnfig=/backup/rman/sys_rman.conf --stanza=kingbase info
stanza: kingbase
    status: ok
    cipher: none
    db (current)
        wal archive min/max (V009R001C001B0025): 000000010000000000000003/00000001000000000000000E
        full backup: 20250418-151727F
            timestamp start/stop: 2025-04-18 15:17:27 / 2025-04-18 15:17:30
            wal start/stop: 000000010000000000000004 / 000000010000000000000005
            database size: 101.9MB, database backup size: 101.9MB
            repo1: backup set size: 101.9MB, backup size: 101.9MB
        full backup: 20250418-155617F
            timestamp start/stop: 2025-04-18 15:56:17 / 2025-04-18 15:56:22
            wal start/stop: 000000010000000000000007 / 000000010000000000000007
            database size: 85.9MB, database backup size: 85.9MB
            repo1: backup set size: 85.9MB, backup size: 85.9MB
        diff backup: 20250418-155617F_20250418-162516D
            timestamp start/stop: 2025-04-18 16:25:16 / 2025-04-18 16:25:17
            wal start/stop: 00000001000000000000000A / 00000001000000000000000A
            database size: 85.9MB, database backup size: 21MB
            repo1: backup set size: 85.9MB, backup size: 21MB
            backup reference list: 20250418-155617F
        incr backup: 20250418-155617F_20250418-163143I
            timestamp start/stop: 2025-04-18 16:31:43 / 2025-04-18 16:31:45
            wal start/stop: 00000001000000000000000D / 00000001000000000000000D
            backup reference list: 20250418-155617F, 20250418-155617F_20250418-162516D
--2、模拟误删除操作并执行不完全恢复。
--(1)查看时间戳。
--(2)删除t01表。
$ ksql -Usystem -dtest
test=# SELECT now();
              now
 2025-04-18 17:09:07.576355+08
(1 row)
test=# drop table t01;
DROP TABLE
test=# select * from t01;
ERROR:  relation "t01" does not exist
LINE 1: select * from t01;
--(3)正常停止数据库,删除/data目录下的所有文件。
$ sys_ctl stop -m fast
$ rm -rf /KingbaseES/V9/data/*
$ rm -rf /KingbaseES/V9/data/.*
$ sys_ctl start
--(4)执行不完全恢复至误删除表之前的时间点。
$ sys_rman --cOnfig=/backup/rman/sys_rman.conf \
  --stanza=kingbase --type=time --target='2025-04-18 17:09:07' \
  --target-action=promote restore
注意:
1.如果不指定 --target-action=promote选项,系统默认会使用 --target-action=pause 选项,此时 系统处于只读状态,需要执行“select pg_wal_replay_resume()”命令使数据库切换时间线,并进入读写状态。
2.实际工作中,往往不清楚准确的误删时间,一般需要多次恢复、使误删除的损失降到最低。
--(5)启动实例。
$ sys_ctl start
--3、恢复结果验证。
--(1)使用system用户登录test数据库。
--(2)查看t01表及数据  (t01表被成功恢复)。
 id | name
  1 | abc
  2 | def
(2 rows)
