Print
知
某局点S12500R-2L macsec对接华为设备,对端接口无法up
12小时前 发表
问题描述
现场在接口下配置macsec对接华为设备,对端接口无法UP
xxx current state : UP (ifindex: 34)
Line protocol current state : DOWN
Description:
Route Port,The Maximum Transmit Unit is 1500,The Maximum Frame Length is 9216
Internet Address is 10.1.4.2/30
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 0418-92b1-f1f2
Port Mode:     COMMON FIBER,     Port Split/Aggregate:               -
Speed:                40000,     Loopback:                        NONE
Duplex:                FULL,     Negotiation:                        -
Input Flow-control: DISABLE,     Output Flow-control:          DISABLE
Mdi:                      -,     Fec:                                -
Last physical up time   : 2026-03-04 02:43:07
Last physical down time : 2026-03-04 02:43:00
Current system time: 2026-03-04 02:48:18
Statistics last cleared:never
    Last 300 seconds input rate: 3 bits/sec, 0 packets/sec
    Last 300 seconds output rate: 397 bits/sec, 0 packets/sec
    Input peak rate 6222 bits/sec, Record time: 2026-03-03 12:11:28
    Output peak rate 6126 bits/sec, Record time: 2026-03-03 10:39:26
    Input :           50978108 bytes,             102601 packets
    Output:           53186809 bytes,             134922 packets
    Input:
      Unicast:                  49618,   Multicast:                   52868
      Broadcast:                  115,   Jumbo:                        8252
      Discard:                      0,   Frames:                         --
      Pause:                        0,   Ignoreds:                        0
      Total Error:                  0
      CRC:                          0,   Giants:                          0
      Jabbers:                     --,   Fragments:                       0
      Runts:                        0,   DropEvents:                      0
      Alignments:                   0,   Symbols:                         0
    Output:
      Unicast:                  49751,   Multicast:                   85122
      Broadcast:                   49,   Jumbo:                        8258
      Discard:                      0,   Buffers Purged:                  0
      Pause:                        0
      Total Error:                  0
    Input bandwidth utilization threshold : 90.00%
    Output bandwidth utilization threshold: 90.00%
    Last 300 seconds input utility rate:  0.01%
    Last 300 seconds output utility rate: 0.01%
过程分析
125R在使用macsec时有如下限制:
对于 KCR 系列单板和 S12500R-48C6D 设备,端口使能 MACSec 功能时,必须配置为 server 模式。
我司GCM-AES-256和GCM-AES-XPN-256加密套件和标准的开源加密套件实现不一致。当对端设备使用GCM-AES-256和GCM-AES-XPN-256的开源加密套件时,我司设备上使用同样的加密套件必须指定standard参数,否则无法与对端设备成功建立MKA会话。
让现场配置macsec cipher-suite gcm-aes-256 standard后,两端接口都不up了。
查看对端相关配置
interface xxx
undo portswitch
ip address a.b.c.d 255.255.255.252
mac-security-profile ds11
mka cak-mode static ckn a1a1a1a100000000000000000000000000000000000000000000000000000000 cak %+%##!!!!!!!!!"!!!!"!!!!*!!!!7L
TnVOK_g:*1(lVHpjf5&S}"'VZ_n6>w+h9!!!!!2jp5!!!!!!Q!!!!Cp|;:$8z$@<=B]P)>dn0FfzJOO^EHSLn]T&In:33V{*}%2EzPE[v`~.3)pe9%+%#
device transceiver 40GBASE-FIBER
return
[xxx] mac-security-profile ds11
[xxx] mac-security-profile name ds11
[xxx-macsec-profile-ds11]disp this
查看对端有无相关限制等因素:
mka cryptographic-algorithm { aes-cmac-128 | aes-cmac-256 | sm4-cmac-128 }设备使用MKA密钥生成算法根据CAK和CKN生成KEK、ICK和SAK。缺省情况下,MKA密钥生成算法为AES-CMAC-128。
解决方法
这块实现与我们有些差异: GCM-AES-128和GCM-AES-XPN-128加密套件要求所使用的CKN、CAK的长度都必须为32个字符。GCM-AES-256和GCM-AES-XPN-256加密套件要求使用的CKN、CAK的长度都必须为64个字符。
华为侧配置mka cryptographic-algorithm aes-cmac-256后,两端成功协商。
