Print
知
ProLiant DL3X5 Gen11 Server - 搭载 AMD EPYC 第四代处理器可能在运行期间遇到Uncorrectable Error/Uncorrectable Machine Check,或在启动内存初始化期间服务器无响应
组网及说明
Advisory: ProLiant DL3X5 Gen11 Server - Systems With AMD EPYC 4th Gen Processors May Experience an Uncorrectable Error\Uncorrectable Machine Check During Runtime, or System Unresponsiveness at Memory Initialization During Boot
文档ID:a00156999en_us    Last Updated: 2026-02-23
影响范围
如下服务器搭载AMD 4th Generation EPYC 处理器:
  • HPE ProLiant DL325 Gen11
  • HPE ProLiant DL345 Gen11
  • HPE ProLiant DL365 Gen11
  • HPE ProLiant DL385 Gen11
问题描述
在某些情况下,HPE ProLiant DL3X5 Gen11 服务器可能会遇到以下问题:
∙             在启动过程中,出现内存初始化错误,导致显示“不支持的 DIMM 配置”,该错误会在启动期间显示并记录到 IML日志中。
或者
∙             在运行期间,在高负载下出现不可纠正内存错误,导致Uncorrectable Machine Check,该异常会被记录到 IML 中。
以下是 DIMM 初始化时服务器无响应情况的报错示例:
"41: DIMM Initialization Error-processor 1 DIMMs 1. The identified memory channel could not be properly trained and has been mapped out. Major Code 0001088, Minor Code 00000002."
"42: Unsupported DIMM configuration detected=Processor 1 violates DIMM Population rules. Action: consult the user guide for more information on supported configurations and population rules."
如下是在高负载情况下服务器出现的Uncorrectable Memory Error 和Uncorrectable Machine Check error 示例:
"Uncorrectable Machine check exception. Error was detected on Processor 2. Uncorrectable machine check exception extended registers. Reseat the processor. Replace the failed DIMM."
过程分析
N/A
解决方法
如果出现此问题,无需更换硬件。升级BIOS (A55/A66)固件版本到3.00_02-06-2026 或更高。
 Online ROM Flash Component for Windows x64 - HPE ProLiant DL325/DL345 Gen11 (A56) Servers | HPE Support
