Print
知
S9827-128DH频繁资源不足告警并恢复
2026-09-22 发表
组网及说明
设备型号:S9827-128DH
设备版本:R9323HS03
告警信息
%Sep 18 13:13:56:238 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/4/RESMON_MINOR: -Resource=underlay_dlb_ecmp_group-Total=128-Used=128-Free=0; Free resource decreased to or below minor threshold 20%. ip forwarding function by underlay_dlb_ecmp_group will be affected.
%Sep 18 13:13:56:239 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/3/RESMON_SEVERE: -Resource=underlay_dlb_ecmp_group-Total=128-Used=128-Free=0; Free resource decreased to or below severe threshold 10%. ip forwarding function by underlay_dlb_ecmp_group will be affected.
%Sep 18 13:13:56:240 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/2/RESMON_USEDUP: -Resource=underlay_dlb_ecmp_group-Total=128-Used=128-Free=0; Resource used up. ip forwarding function by underlay_dlb_ecmp_group will be affected.
%Sep 18 13:14:26:962 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/5/RESMON_USEDUP_RECOVERY: -Resource=underlay_dlb_ecmp_group-Total=128-Used=33-Free=95; Free resource increased from zero up. ip forwarding function by underlay_dlb_ecmp_group will be affected.
%Sep 18 13:14:26:962 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/5/RESMON_SEVERE_RECOVERY: -Resource=underlay_dlb_ecmp_group-Total=128-Used=33-Free=95; Free resource increased above severe threshold 10%. ip forwarding function by underlay_dlb_ecmp_group will be affected.
%Sep 18 13:14:26:962 2026 xn01-401-d17-gpu-asw-c1p2-h9827-5.xn RESMON/5/RESMON_MINOR_RECOVERY: -Resource=underlay_dlb_ecmp_group-Total=128-Used=33-Free=95; Free resource increased above minor threshold 20%. ip forwarding function by underlay_dlb_ecmp_group will be affected.
问题描述
客户设备运行过程中出现资源不足告警,告警信息如上。
(1)这个资源代表的是什么?给什么功能使用的?
(2)为什么会出现资源不足的告警?
 (3)后续为什么恢复了,是否还会再次出现?
(4)另外,在这种资源满的情况,是否会影响他AR置位转发的功能?
# 匹配ar标志位进行逐包
 acl number 3000 name LOAD_SHARING
  rule 10 permit ip
 ecmp mode spray
 ip load-sharing acl ipv4 3000
 acl number 5000 name SET_AR_POLICY
  rule 5 permit udp destination-port eq 4791 l4 40 ff 16
 policy-based-route AR permit node 10
 if-match acl user-defined 5000
 ip global policy-based-route AR
 ip load-sharing mode per-flow dest-ip src-ip ip-pro dest-port src-port global
 ip load-sharing mode per-flow algorithm 5 global
过程分析
(1)该资源主要用于存储Underlay网络的ECMP等价路由组信息,供DLB及其它逐流或逐包负载均衡功能使用。
(2)(3)路由变化不稳定,把底层资源一瞬间占完了。持续看下display resource-monitor,看下这个资源underlay_dlb_ecmp_group没持续少就没问题
(4)AR 置位功能不依赖 underlay_dlb_ecmp_group,所以不会影响AR置位转发的功能。
解决方法
如上。
