Print
知
S3X00V3系列交换机OSPF单域配置方法(命令行版)
2018-11-28 发表
组网及说明
1.1适用产品系列
本案例适用于如S3100V3-28TP-SI、S3100V3-28TP-EI、S3100V3-20TP-PWR-SI、S3100V3-28TP-PWR-EI等S3100V3系列的交换机。
1.2配置需求
SWA和SWB通过VLAN20互联、通过OSPF路由协议实现PC1和PC2的互连互通。
2 组网图
配置步骤
3.1 SWA配置
#创建vlan10和vlan20,并把G1/0/1口加入vlan10、1/0/2口加入vlan20 ,并且配置vlan10和vlan20 的虚接口地址
<SWA>system-view
System View: return to User View with Ctrl+Z.
[SWA]vlan 10
[SWA-vlan10]port GigabitEthernet 1/0/1
[SWA-vlan10]quit
[SWA]vlan 20
[SWA-vlan20]port GigabitEthernet 1/0/2
[SWA-vlan20]quit
[SWA]interface vlan 10
[SWA-Vlan-interface10]ip address 192.168.10.1 255.255.255.0
[SWA-Vlan-interface10]quit
[SWA]interface vlan 20
[SWA-Vlan-interface20]ip address 192.168.20.1 255.255.255.0
[SWA-Vlan-interface20]quit
#启动ospf协议,并设置路由器的router id
[SWA]ospf 1 router-id 192.168.20.1
#配置区域0并且发布网段
[SWA-ospf-1]area 0
[SWA-ospf-1-area-0.0.0.0]network 192.168.10.0 0.0.0.255
[SWA-ospf-1-area-0.0.0.0]network 192.168.20.0 0.0.0.255
[SWA-ospf-1-area-0.0.0.0]quit
[SWA-ospf-1]quit
#保存配置
[SWA]save force
3.2 SWB配置
#创建vlan10和vlan30,并把G1/0/1口加入vlan20、1/0/2口加入vlan30 ,并且配置vlan20和vlan30 的虚接口地址
<SWB>system-view
[SWB]vlan 20
[SWB-vlan20]port GigabitEthernet 1/0/1
[SWB-vlan20]quit
[SWB]vlan 30
[SWB-vlan30]port GigabitEthernet 1/0/2
[SWB-vlan30]quit
[SWB]interface vlan 20
[SWB-Vlan-interface20]ip address 192.168.20.2 255.255.255.0
[SWB-Vlan-interface20]quit
[SWB]interface vlan 30
[SWB-Vlan-interface30]ip address 192.168.30.1 255.255.255.0
[SWB-Vlan-interface30]quit
[SWB]ospf 1 router-id 192.168.20.2
#配置区域0并且发布网段
[SWB-ospf-1]area 0
[SWB-ospf-1-area-0.0.0.0]network 192.168.20.0 0.0.0.255
[SWB-ospf-1-area-0.0.0.0]network 192.168.30.0 0.0.0.255
[SWB-ospf-1-area-0.0.0.0]quit
[SWB-ospf-1]quit
#保存配置
[SWB]save force
3.3 验证配置
# 查看Switch A的OSPF邻居
<SWA>display ospf peer
         OSPF Process 1 with Router ID 192.168.20.1
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 192.168.20.2    192.168.20.2    1   35         Full/BDR          Vlan20
#查看Switch A的OSPF路由信息
<SWA>display ospf routing
                  Routing Table
                Topology base (MTID 0)
 Routing for network
 Destination        Cost     Type    NextHop         AdvRouter       Area
 192.168.10.0/24    1        Stub    0.0.0.0         192.168.20.1    0.0.0.0
 192.168.30.0/24    2        Stub    192.168.20.2    192.168.20.2    0.0.0.0
 192.168.20.0/24    1        Transit 0.0.0.0         192.168.20.1    0.0.0.0
#查看Switch A的路由表信息,有到192.168.30.0/24网段的路由
<SWA>display ip routing-table
Destinations : 17       Routes : 17
Destination/Mask   Proto   Pre Cost        NextHop         Interface
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
127.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
192.168.10.0/24    Direct  0   0           192.168.10.1    Vlan10
192.168.10.0/32    Direct  0   0           192.168.10.1    Vlan10
192.168.10.1/32    Direct  0   0           127.0.0.1       InLoop0
192.168.10.255/32  Direct  0   0           192.168.10.1    Vlan10
192.168.20.0/24    Direct  0   0           192.168.20.1    Vlan20
192.168.20.0/32    Direct  0   0           192.168.20.1    Vlan20
192.168.20.1/32    Direct  0   0           127.0.0.1       InLoop0
192.168.20.255/32  Direct  0   0           192.168.20.1    Vlan20
192.168.30.0/24    O_INTRA 10  2           192.168.20.2    Vlan20
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# PC1 ping PC2 正常通信
C:\Users\mfw2656>ping 192.168.30.2
Ping 192.168.30.2 (192.168.30.2): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.30.2: icmp_seq=0 ttl=254 time=8.000 ms
56 bytes from 192.168.30.2: icmp_seq=1 ttl=254 time=2.000 ms
56 bytes from 192.168.30.2: icmp_seq=2 ttl=254 time=3.000 ms
56 bytes from 192.168.30.2: icmp_seq=3 ttl=254 time=3.000 ms
192.168.30.2 的 Ping 统计信息:
      数据包: 已发送 = 4,已接收 = 4,丢失 = 0 (0% 丢失),
返行程的估计时间(以毫秒为单位):
      最短 = 2ms,最长 = 3ms,平均 = 2ms
配置关键点
