MSR2600按向导配置后不能上网
2024-04-27提问
  • 0收藏,134浏览
MSR2600按向导配置后不能上网,WAN口可以获取到IP地址。但是LAN口不能上网。LAN口IP172.10.10.1电脑从LAN口获取的DHCP172.10.10.100网关172.10.10.1子网255.255.255.0
wan口配置为自动获取IP上网。获取到192.168.88.113  上一个路由IP为192.168.88.1 从LAN口也ping不通192.168.88.1 。但是可以ping通192.168.88.113怎么配置才能正常上网。配置的文件如下
 version 5.20, Release 2516P28
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 172.10.10.100 172.10.10.254
 network mask 255.255.255.0
 gateway-list 172.10.10.1
 dns-list 202.99.224.68 202.99.224.8
user-group system
 group-attribute allow-guest
local-user admin
 authorization-attribute level 3
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface NULL0
interface Vlan-interface1
 ip address 172.10.10.1 255.255.255.0
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
interface GigabitEthernet0/1
 ip address dhcp-alloc
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 ip route-static 192.168.88.0 255.255.255.0 Vlan-interface1 172.10.10.101
 dhcp enable
 ip https enable
 nms primary monitor-interface GigabitEthernet0/1
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
静态路由写错了, ip route-static 0.0.0.0 0 加上wan口直连的下一跳日志,然后在wan口上配置nat outbound
大佬,我是web页面下配置的。web页面下怎么操作。
zhiliao_fXjtRx 发表时间:2024-04-27
粉丝:2人 关注:1人
wan口差一条 命令
nat outbound
zhiliao_fXjtRx 知了小白
下面为WAN接口状态!静态路由内也有您说的0.0.0.0 static 下一跳192.168.88.1
GigabitEthernet0/1 当前状态: UP
链路层协议当前状态:UP
描述: GigabitEthernet0/1 Interface
最大传输单元是 1500
本接口地址是192.168.88.113/24, 来自DHCP动态获取
IP报文发送帧格式: PKTFMT_ETHNT_2, 硬件地址是 9c06-1ba5-8015
IPv6报文发送帧格式: PKTFMT_ETHNT_2, 硬件地址是 9c06-1ba5-8015
传输介质类型: 双绞线, 环回: 无, 非混杂模式
1000Mb/s速率, 全双工, 连接类型是: 自协商
输出流控禁止,输入流控禁止
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
上次计数器清零时间: 没有
300秒输入速率为 183.64 字节/秒, 1469 位/秒, 2.27 报文/秒
300秒输出速率为 58.75 字节/秒, 470 位/秒, 0.78 报文/秒
收到 报文: 3049, 字节: 233677, 缓冲区: 3049
收到: 2707 广播包, 276 多播包,0 接收流控帧
输入错误: 0, 0 超短包, 0 超长包,
0 校验和错误, 0 对齐错误, 0 上溢错误,
0 dribble 包被接收, 0 接收丢弃, 0 无接收缓冲区
发送 报文: 1562, 字节: 122959, 缓冲区: 1562
发送 13 广播包, 0 多播包, 0 发送流控帧
输出错误: 0, 0 下溢错误, 0 输出碰撞错误
0 包被滞后发送, 0 丢失载波
